Need help with a CTC-15 vertical problem!
I’m working on a ctc-15. Everything was going smoothly until I noticed that I can’t adjust the height at all. The picture looks squashed. The height pot is good. All the resistors in the circuit are good, I checked all of the capacitors. Swapped out the vertical output tube and nothing. The grid of the vertical output wants 30 volts, but jumps around between 3 and 5, adjusting the control only changes it by half a volt or so.
Would anyone know what could be causing this problem? I’ve been stuck on it for days now |
you are sure that the convergence PCB is plugged in and working correctly, cause if is not plugged in and working, it wont get the right load/ feedback and you will only get half sweep.
I know you said you checked the caps, but if it's pulling up from the bottom sub the 50 mike on pin 3 of the output.
It fixed a lot of them 50+ years ago. But then again that was 50+ years ago. |
If the pix has good lin & caps are fresh its usually one of the
high ohm resistors feeding the height control. You have to lift one end to properly measure them. 73 Zeno ![]() LFOD ! |
Most common cause is the electrolytic coming off the cathode of the vert output. Plate load resistor of the vert oscillator often goes 'waay off spec (high) due to being hammered by high level spike.
This is not a widescreen program. The linearity looks fine. There is just not enough deflection |
http://videokarma.org/showthread.php?t=271514&page=5 on MINE, a CTC-16xl i had to replace what is R105 & R106 on your CTC-15, the resistors on each side of the height pot, they were way off on mine.
You indicate all resistors check good. But double-check R104. It's a 2.2 meg half-watt, going to pin 8 of the 6GF7. It's the plate load resistor of the vert osc. https://www.earlytelevision.org/pdf/...ams_0673-2.pdf
Yep. Scratch that one off. A good thing to bookmark though. It's a frequent failure point in designs that run the vert osc from B Boost (not just RCA)
If you have checked all the resistors involved, and know that they are OK, and same with all the caps that could be causing the issue, cause they often can be a bit sneaky and leak at operational voltage, and hard to really test unless you have a tester that will push it to it's limits like the vintage cap testers would, but if you are sure the caps are good, and the boost voltage is within the correct range, one thing to try is a resistance test of the vertical winding of the yoke, YEL & YEL-BLK terminals, should be about 23.5 ohms.
![]() Glad to hear it! That seems to be a common fault, cause as mentioned, it was also just as bad in my set.
Another congratulations that you found it. Gosh, sometimes we just have to scratch our head!
