I changed the scope connectors on the front panel of my B&K over to BNC connectors (it literally was unsolder the center pin, unbolt old connector, bolt in new connector, and resolder center wire) so I can connect it to the scope with simple common cables with BNC at both ends...Works like a charm with the scope in XY mode. Have only tried one alignment so far.
