I would try the tube in a working TV set before trying something as risky as remove shorts. I had a 10BP4 like that and it worked fine in an actual TV with the short to the point I'd have never guessed if I had restored the TV without testing it.
When you have good emissions don't risk it until you have seen picture on screen to know you have an actual problem.
