Old 06-14-2024, 03:23 AM
YamahaFreak's Avatar
YamahaFreak YamahaFreak is offline
<-- CSXT 6038, EMD GP40-2
Originally Posted by JohnCT View Post
I have one if you want it - I don't take these in anymore for service.
Part number LJ92-01729A
A couple of caveats. The 50C550 is a 1080P panel and the ribbons from the panel to the buffer board are a bit difficult to remove and difficult to seat in the connector. When I install them, I use an Optivisor to make sure the ribbon's two notches are seated fully down in the connector. They may look good at first but when you see them with magnification, you'll see what I'm talking about. If you're nearsighted then this won't be a problem.
This board was marked good by me which means it was either pulled from a running panel or tried in another panel and verified, so it *should* be good.
If you want it, it's yours for the asking.
John
Hi John,
I'm not sure how I never saw your reply, I'm sorry! I'm still using this C550 and yes, I'll gladly accept your offer, if you still have that board!
Sony Trinitron Fan
