Old 07-23-2024, 08:43 PM
bhegges bhegges is offline
Originally Posted by Tom9589 View Post
Any chance of you having this CRT tested? It would be interesting to see how good the tube is.
I have a Sencore CR70 and this is the best roundie I have tested. Equal cutoff and emission measurements on all guns, and the emission holds steady under the life test button. Below is the emission measurement. I assume each testers measure a bit different plus I have no idea what a NOS roundie would test at. If someone has tested a NOS roundie on a CR70 I would be interested in what the reading was.
Back to the question about if this tube was rebuilt. I have 2 rebuilt tubes that have rebuilt labels and there is a definite ridge that I can feel and see. This Telix tube does not have this. No one has commented that Telix was a OEM which suggests this company removed the labels or received un-labeled tubes and would in turn sell them, likely discounted. Note while possible I doubt someone removed just the OEM label, further the Telix label is well attached so unlikely that this label survived while the OEM label fell off. Thanks everyone for the discussion.
