Old 10-04-2024, 01:57 PM
I didn't see anything that concerned me so I pulled the HO and damper tubes and did a slow power up.
After about an hour, I was up to 115 with no issues. Popped the tubes back in and after some control fiddling, got a raster!
Controls works as expected except for height. Adjusting it doesn't seem to do much and I do not have full deflection.
Hooked up a converter box and was able to pull in a pretty good image and sound. Just like the GE I had to put the fine tuning at the edge of losing the station to get sound and color.
That's good - means it's likely an issue with my signal source and not alignment.
Next up, I'll test tubes and check out the height control.
