Old 05-28-2025, 12:21 PM
Why put a fan that was never intended for some things I was told with the old sets that they are supposed to get hot to work right. A fan to cool a hot flyback I don’t think that would be much help since the heat comes from within the depths of the flyback. I guess a type of shield to keep tube heat away would help.
Flybacks are not supposed to run warmer than bath water. If they do either something in the circuit needs attention or extra cooling is necessary. Sweep circuits don't need to be hot to work. The tuner and IF might as the caps are sometimes temperature dependent for exact value for proper alignment behavior.
