Old 06-21-2025, 08:25 PM
I can see the pictures now without taking the image address and opening it in a new tab,
so whatever you did good job.... So When you turn the yoke 45 degrees in any
direction - the faint vert. lines remain at the same 0 degrees as they appear
now....? Can you post a pic of that? I was going to suggest it is an anomaly
in the signal that that tv is susceptible to while others are not. And it may
also only be on that one level of the game... Might be something you
may need a scope to figure out.... But I really would like to see
the screen with those lines, & the yoke turned 45 degrees....
Does it get less pronounced with the brightness & or,
contrast turned down...? Could it be a over-scan
related anomaly? Or something is happening
off screen in the far edge of the scan line
from that game.... Alien messages
come to mind.....
