Old 10-22-2025, 10:13 AM
Penthode's Avatar
Penthode Penthode is offline
The barrelling is what is known as pincushion. It is exacerbated by the geometry of the tube eg wide deflection angle and flat screen. I don't that is the case here.
What I think your case is due to is magnetization of the steel CRT bell. The beam as it deflects to the edges of the raster image is likely being affected by the magnetism of the bell.
I suspect if you can degauss the CRT bell, the pincushion effect will disappear and the edges of the raster will be straight.
