Old 11-13-2025, 07:07 PM
I basically agree with Bob. For a CTC-5 like that $350 is about the going rate. The 21AXP22 in those CTC-5 color sets is a metal cone and prone to going gassy.... Other CTC-5s are about the only somewhat common somewhat affordable source...All later all glass round color CRTs are electrically compatible but require a bit of work to mechanically adapt(there's threads here on that). The CTC-5 is the most Muntz-like chassis of the RCA roundys (heck, Muntz started building RCA color clones with the CTC-5)... Most RCA color chassis are significantly better than the CTC-5.
A fine point: the CTC-5 Super chassis is the cheapest, poorest performing and most common one, of which you speak. The rarer Deluxe chassis is closer to the CTC-7 and following chassis versions.
