Old 12-27-2025, 12:48 PM
Penthode's Avatar
Penthode Penthode is offline
Originally Posted by tubesrule View Post
Last time in the hopes that anyone reading this in the future will not have bad information. The pages from Television II clearly show the 343 was 2.25MHz spacing and the 441 was 3.25MHz spacing.
NO, as all the actual dated original documents that have been presented here have shown, the 343 line field test was NEVER at 3.25MHz carrier spacing. The RF Alignment manual I copied showed they were aligning the 343 line RR-359 sets to 2.25MHz in November of 1936. I fail to understand your instance to the contrary without ever providing a single piece of original documentation of support.
I went back to read the Joffieffe presentation to the FCC on June 15, 1936. In it Jollieffe asserts a resolution around 440 lines and the need for a 6 MHz channel. However he explains that the construction of the transmitter for the July 1936 first television demonstration was 343 line and a 2.25MHz carrier spacing.
So the impeding move to 441 line was pending, I have not found a date for it's first public demonstration but i suspect it must have been late 1936 or early 1937.
So for the record, I fully agree with your statement and appreciate your dilligent clarification.
