Did you replace all caps? We worked on one of these that wouldn't lock in horizontally on its initial testing with the old caps and we found a paper cap that was thermally intermittent...replacing all those caps did the trick.
I guess the screw sealed up the leak in the electrolytic and it initially did not deteriorate too much! |
