Time to get this site upgraded, so we are passing the hat around. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Go to Page...
If I get this right, you should see a picture of a few of my faves. 3 Sony ICRs, L to R: - an ICR-120, an ICR-200 and an ICR-100.
In the foreground is a rechargeable battery as used in the 2 small ones (the ICR-200 also uses rechargeable batteries, a little bigger). Both the ICR-120 and ICR-200 were supplied with a "walwart" style charger but the ICR-100 has an ingenious case which the radio fits into. When the case is closed, two pins fold out for insertion into a US type wall socket. An example of the charger is in front of the radios.
The volume of these radios is remarkable and for an idea of size, the little medallion on the end of the chain is about the size of a nickel!
Cheers! Haggis.
