Old 06-08-2019, 04:12 PM
Just for grins and giggles, have you tried disconnecting the ground wire to see if things get better or worse?
Another thought: are your receiver and turntable plugged into the same outlet?
Actually when I disconnect the ground the hum did go away oddly enough but then when I touched the ground wire plug that goes into the turntable it would hum again.
As for what the turntable is plugged into, it's plugged into the switched outlet on the back of my receiver.
