Old 06-09-2019, 09:29 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Originally Posted by maxhifi View Post
Also, shure cartridges sometimes strap one negative terminal to chassis ground, meaning if it does not hum with the ground wire disconnected leave it disconnected. This isn't a safety ground, it's just for hum reduction
Not just Shure does that. Most all MM cartridges come with that strap to ground at one of the G terminals. If the tone arm head shell is metal or plastic with a ground to the cartridge body, that strap can sometimes cause a ground loop and hum. Remove that strap if using a metal or grounded head shell.
