Old 04-21-2021, 10:00 PM
AVTechMan AVTechMan is offline
Aspiring Videographer
Originally Posted by newzealand View Post
well it is here
its in perfect cosmetic cond
it was displaying a few faults but that was remedied by replacing a belt and lubing the mechanical movements ,works well now,
i have checked the sound out and it is good on head phones,
im yet to check picher out as i need a svhs cable ,
that is proving hard work ,its a 7 pin din like plug,im guessing ill need this plug on one end a s-video on the other end
does any one know what that plug is called?
That plug is usually known as the Y/C 388 connector and on those decks that's what their 'SVHS' cables are and plug into. I have the BR-S822U and the S525U decks and uses that same cable.
You will need the Y/C male 7-pin to 4-pin DIN adapter. I had mine made from a company called Markertek but that was several years ago, and don't know if they make those cables anymore. You would have to call and ask.
