Old 08-27-2022, 05:12 PM
I could answer all you wrote if you want my number let me know it will only take a few minutes so much typing lol. The audio trans checks perfect 80-81-82 resistors perfect and after having the set on the last time I had an antenna on channel 3 fades alittle probably out of tune but channel 4 sound was perfect but heard no snow with antenna off and yes I made a mistake pin 2 is a green wire is the wiper set on it measured 280 mv But the tube didn’t red plate until I had the chassis out and found the 150 resistor burned. The tube just seemed to get really hot fast now I find within 30 seconds the 6aw8 and the video output 6hb6 get really hot fast I have read that low b+ is not good for tubes maybe things change with the tube conducing at low voltage. My initial finding was I had no video so maybe something in the video area causing all this.
