Old 08-27-2022, 06:49 PM
It is always possible you have more than one problem. If you suspect the Video Output
tube is using too much current, then you need to do voltage checks at each pin & see
if you find any burnt looking parts in that circuit. It's also sourced to the 385V.
The video amp 6AW8A is also sourced to the 385V.
But if the audio out tube accounts for all the extra power supply draw, then we may be
getting ahead of ourselves.
