Hi
I believe measuring resistance from one side of the IF Coupling Transformers, or IF Coils is not necessary, and you can achieve better results measuring voltages, like for example Pin 7 of V1, and and Pin 2 of V2. If the Primary, & Secondary had some short, or leakage it would show itself with 200V on one side, if the insulation were to break down at the 200V operating voltage it would show on grid of V2, and be more telling. I'm wondering what the voltage on pin 8 of V2 is...? They are almost the same circuit, and with almost the same voltages on all the same tube pins...... Same resistor voltage dividers too...... I'm also wondering if these voltages are a result of no signal from the tuner.... Have you tried hooking up your tuner subber to this tv & putting a signal on it and leaving the tuner power plug hooked up to the tuner, but just removing the RCA plug to the IF, & putting the Tuner Sub box in..... And then measure these voltages...? .
