Old 06-05-2025, 12:16 PM
Chris K Chris K is offline
OMG I'm so sorry to hear that! Power transformers, yokes, flybacks and tuners are my top dreads for failures. Best of luck with the replacement.
Old 06-05-2025, 12:19 PM
So now I'm stuck with trying a flyback transformer that's alien to the set, ram x032 and sort of a match, OR, trying something really crazy and Frankenstein like...
Did you check the list of spares harvested on the ETF website? I actually found an RCA VOT there that was the same part number as the one that failed on me.
Old 06-05-2025, 01:03 PM
been looking weekly, they seem to be out of compatible ones.
Old 06-05-2025, 01:31 PM
I will post pics and resistance readings of all 3 flybacks tonight, the OEM (with the corroded eyelets ) , fried HVO-5 and RAM X032.
Old 06-05-2025, 08:33 PM
OK
first the OEM
that was in BAD shape, you can see the corroded wires and contacts, which prompted me to replace it.
http://suzaku.live-evil.org/0605251956.jpg
readings
1-2 39.5 ohms
2-3 23 ohms
6-5 0.6 ohms
5-4 6.9 ohms
the dead hvo-5
http://suzaku.live-evil.org/0605251957.jpg
it seems to have thinner wires than the OEM for 1-2, perhaps that;s why it burned?
readings.
1-2 1.8k OUCH!
2-3 40 OHMS
6-5 .0.6 ohms
5-4 6.8 ohms
http://suzaku.live-evil.org/0605251958.jpg
RAM 0x32
1-2 36 ohms
2-3 317 ohms not surprising since its a 13-14k, output.
5-4 0.6 ohms
5-4 6.4 ohms
5-7 9.3 ohms
one note. the heater for the HV rect has only one turn where the others have 2 , this will have to be changed.
with all this, I do think this will work, unless someone else sees something i have not.
Old 06-06-2025, 08:27 AM
More complicated will be the issue of proper matching with the yoke. They interact in final image width and linearity. Some are sensitive and affects the HV level due to dependence of the yoke load/resonance.
Old 06-06-2025, 08:55 AM
no problem!
the maggie yoke is 360330-7 which the RAM replacement is Y70F08, which is the one it says to use with this flyback, so it should be OK.
Old 06-06-2025, 09:00 AM
I would not add another loop for the HV rectifier filament. If there's enough power going though it to produce the proper deflection and HV, the filament voltage/current will be correct.
All the B&W rectifier tubes use the same filament power. 1.25v @ 0.2A.
Old 06-06-2025, 09:21 AM
should i remove the 4.7 ohm resistor or leave it in line?
Old 06-06-2025, 12:05 PM
no problem!
Perfect!
Old 06-06-2025, 12:13 PM
Always using an inline resistor for current limiting. Typically, they are 3.3 - 4.7 ohms.
Old 06-06-2025, 01:07 PM
Tks,
I was not sure, as the paperwork that came with the RAM showing the "typical circuit" had no resistor, it also shows the damper plate hooked to P7 and yoke H to P4, but I will hook both to P4 in this case as it originally was wired OEM.
Old 06-06-2025, 02:52 PM
Worst case you can use a solid state HV rectifier diode
Old 06-06-2025, 03:25 PM
Such as a NTE508...
thought of that.
tried one in my CTC 16XL and it went FOOM.
but this will be at much less voltage and load, perhaps it will hold up and w/o the heater, it's less load on things, just a wee bit.
Old 06-06-2025, 05:44 PM
Rated for 45,000 volts and 110mA peak/5mA average current! No way it should have crapped out.
